Corvair steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2003, 07:02 AM
Post Corvair steering box
How do you adjust the steering box? The pitman arm moves too far to the right and hardly to the left. I reversed the box so that I can use it in my T Bucket.
[ May 27, 2003: Message edited by: Skip Shear ]</p>
Old 05-27-2003, 08:41 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Post
sounds like its still in the car, if so then the pitman arm needs to moved (rotated. what I would do it remove pitman arm, the turn steering wheel from lock to lock & count the ### of rotations, then divide by 2, that way you know where center is on the steering box. center the box & the put pitman arm back on....BUT IF this isnt the problem I would say your box is junk then cause its in a bind, because the adjustment you're talking about will only take the play out of the steering box...joe
Old 05-27-2003, 03:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
What he said. The pittman arm needs to be recentered as TooMany describes. The problem is the pittman arm has a missing tooth in the spline that matches the sector shaft so it will only go on one way. Great if you are using it to cross steer a stock 'vair but must be modified for the reversed box hung on a hot rod frame rail. I use a triangle machinist's file to cut the missing tooth in the spline in the hole of the pittman arm so it will slide onto the sector shaft at any angle.
[ May 28, 2003: Message edited by: willys36@aol.com ]</p>
