Corvette 68 Rear End Pinion Seal...
6-06-06
Rear Pinion Seal Leaking In Tight Space --After Owning 7 Corvettes Been Under On Them Think I'd Know All Answers---Take It Repair Shop Has Rack--My Days Under Cars ---Neck Back Killen Me... Got Estimates, One Guy Wants Dis Assemble Rear End To Remove Pinion Yoke i.e.Claims Side Yokes Could Be Bad!? 74,000 Org Miles--- No Other Leaks Or Side Play No Vibration No Noise Any Speeds---1/2 Shaft (4) Joints & Universal (2) Joints I Did Replaced Past! Any Corvette Guys Here Had Rear End Problems-I Just Want To Replace Rear Pinion Seal- You I Know Tearing Positraction R E Apart Like Opening Hornets Nest... Thanks... E MAIL: Mean@MeanMother.Com {{{ Com Is Missing? }}} Vincent Auto Last edited by Mean@MeanMother; 06-06-2006 at 05:34 PM. Reason: ,Com Is Missing? |
You might want to look at this recent thread. Seems to be the same sort of question.
Replacing Rear Diff Pinion Seal...question??? |
My Gratitude Kind Response...
6-8-06
It's Like Who Do You Trust--You Learn Know Alot About Cars/Trucks/Corvettes! Corvette Limited Slip (Positraction) More Complex -- Cramp Closed Space --Even Hanging Down On Rack-- Factory Set Up,i.e.If I'd Drag Raced 28 Years--End Yokes Loose Bearings Worn. Forgot: Past Year Con Dealer Kept Corvette 3 Days Hopes Dis Assembling Rear End Replace Pinion Seal--Could Not Remove Rear Yoke--Lied About Lubricating Vette, Gear Oil --Tried Keep New Oil Seal & My 2nd Set Keys-- Filed Credit Card Dispute (Got $ Back) Almost Punched Him Out! See Spec Sheet Dis Assembled Corvette Positraction Rear End -- Those Never Seen Under Side Older Corvettes... Again, Thank You All ... Vincent Auto Last edited by Mean@MeanMother; 06-08-2006 at 08:57 PM. Reason: Photos To Big |
Just using the word "Corvette" in front of anything adds $$$ to the price. The actual gear assembly is just a standard GM posi unit but everything else is strickly Vette and scares a lot of people. I rebuilt my 74 from a bare frame up and it Was an Experience! It did take a 3/4" drive Tee Bar and 6' of pipe for a cheater bar to break the pinion nut loose. So breaking that nut loose can be a *****. I would still try to just replace the seal. The rubber in them gets hard with age and IF you don't have any other issues with the rear (gear wine, clunks, ect) I always go with the old addage "If it ain't broke don't fix it". Good Luck. See my album for pics of the rebuild.
| ford rear end | jay1 | Introduce Yourself | 1 | 09-18-2004 03:29 AM |
| Important rear end mounting question | 71gtx | Transmission - Rearend | 2 | 01-04-2004 06:05 PM |
| anyone running 700r4 with 3.55or 3.77 rear end? | 37 chevy | Transmission - Rearend | 7 | 01-06-2003 06:34 AM |
| Rear end | Buffed | Engine | 3 | 10-31-2002 05:11 AM |
| Corvette rear end in a 51 Chevy p/u 3100 | oldford | Transmission - Rearend | 2 | 04-30-2002 12:33 PM |
