corvette column - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 08:55 PM
71corvette's Avatar
corvette column
can I get a 76 corvette tilt /tele steering column to fit in my 50 chevy truck? if so what brackets would I need? I am going with a mustang II front suspension with rack and pinion steering. do they just make some universal couplings and shafts?
Old 12-29-2007, 07:03 AM
31 five window
Last journal entry: grill and rear end
I cannot answer your ? directly but here goes. The length is what matters. Measure to see if when lined up where you want it at the dash will it reach through the fire wall where you want it to exit. You will have to fab a dash mount but floor mounts are available. Yes Flaming river makes just about any combo of u-joint you could want. Hope this helps.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
63 Corvette steering column frankenvette Suspension - Brakes - Steering 6 11-28-2007 06:58 PM
interior paint for steering column corvette dmx6 Body - Exterior 3 10-26-2007 07:17 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 03:29 AM
