-   -   Corvette front brakes on '70 Impala, problem... (http://www.hotrodders.com/forum/corvette-front-brakes-70-impala-problem-222606.html)
wave1957 08-06-2012 02:50 PM
I had read this thread called "1970 Impala Disc Conversion" some time ago on this forum, which describes that it is very easy to mount '69-'82 Corvette front brakes on the stock spindles of a '69-'70 disc brakes Impala. I had also seen that conversion explained somewhere else online.
Seemed simpl, so I jumped in, and met a problem:
The Corvette rotor carrier/bracket, which mount on the spindle, does not fit!
Corvette and Impala spindles are the same part number, so this is not the issue, the bracket is the issue.
Obviously some people have done this conversion before, what caliper bracket have you used?
Thanks!
wave1957 08-07-2012 10:30 AM
After reading more and thinking about this, it seems the steering knuckle is the issue, it is not quite the same part between the 2 cars... Can anyone confirm that before I go and buy the Corvette pieces?
wave1957 08-14-2012 11:46 AM
I guess I had a bad couple of days... my mind was failing me...
The caliper brackets from the Corvette work just fine, but I did have to use the Corvette steering arm knuckles.
Everything is now in place, cool! It really is a bolt-on!
