Corvette front brakes on '70 Impala, problem... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 02:50 PM
I had read this thread called "1970 Impala Disc Conversion" some time ago on this forum, which describes that it is very easy to mount '69-'82 Corvette front brakes on the stock spindles of a '69-'70 disc brakes Impala. I had also seen that conversion explained somewhere else online.
Seemed simpl, so I jumped in, and met a problem:
The Corvette rotor carrier/bracket, which mount on the spindle, does not fit!
Corvette and Impala spindles are the same part number, so this is not the issue, the bracket is the issue.
Obviously some people have done this conversion before, what caliper bracket have you used?
Thanks!
Old 08-07-2012, 10:30 AM
After reading more and thinking about this, it seems the steering knuckle is the issue, it is not quite the same part between the 2 cars... Can anyone confirm that before I go and buy the Corvette pieces?
Old 08-14-2012, 11:46 AM
I guess I had a bad couple of days... my mind was failing me...
The caliper brackets from the Corvette work just fine, but I did have to use the Corvette steering arm knuckles.
Everything is now in place, cool! It really is a bolt-on!
66 impala front brakes starliner Suspension - Brakes - Steering 6 08-15-2012 08:04 AM
Corvette spindles on '70 Impala wave1957 Suspension - Brakes - Steering 2 01-13-2012 07:10 PM
Corvette Summer Corvette Front Clip MADTECH72 Body - Exterior 18 04-16-2008 08:45 PM
66 impala front brakes starliner Suspension - Brakes - Steering 7 04-29-2005 02:49 AM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 06:52 PM
