Corvette gear ratio ? How to determine ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 09:39 AM
How do I find out what gears are in my rear end??? Does IRS change the method. I measure at the drive line and I get 1.75 turn of the drive line to one turn of the wheel. When I measure at the half shaft I get 1 to 1. It's a 1973 Vette.
Old 06-01-2013, 10:06 AM
vinniekq2's Avatar
all Corvettes are posi,so jack up the car and turn the drive shaft until the tires turn one revolution.
or do the same thing until the tires turn 10x and divide by 10 for a more accurate indicator
Old 06-01-2013, 10:47 AM
Northstar T's Avatar
Gone sailing
If the factory gears have not been changed, there is a code stamped on the bottom flange of the diff case. for 73 they would be:
Code Ratio
AA 3.55
AB 3.70
AC 4.11
AW 3.08
AX 3.36
LR 3.36
Russ
Old 06-03-2013, 06:10 AM
artsvettes's Avatar
All corvette rears were not posi
Old 06-03-2013, 06:43 AM
vinniekq2's Avatar
independent or solid axle?
Pre 62 vettes? I have never seen a 63 vette or newer(dana) that was not posi,thanks for the info.
having non posi in a sports car is kind of strange,especially the companies flagship
Old 06-03-2013, 06:46 AM
Wiki Edits: 27
gear ratio check
for any car count the turns of the drive shaft for BOTH wheels to turn ONE time, or for One wheel to turn TWO times. The older a car is the more chances that the gears have been changed .
Richmond Gear 5-speed,Why all the first gear ratio options? Argess Transmission - Rearend 1 10-17-2011 07:11 AM
Trying to determine rear ratio yragat Transmission - Rearend 4 09-15-2010 04:00 PM
how to determine the right ratio Ratoflic Transmission - Rearend 4 07-07-2007 04:04 PM
Rear End Ratio Why 3.42 in the corvette x711 Transmission - Rearend 7 01-01-2007 09:20 PM
How to determine gear ratio in Ford 9" Kaylah Hotrodding Basics 7 10-21-2003 08:18 PM
