corvette headers for side pipes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2006, 08:13 PM
i have a 64 corvette that i plan to put 2.5 stock side pipes from a 67 vette. can someone let me know if you can put any kind of after market header that will work with this set up. i do not want to use the stock manifolds, and do not want to use the hooker side pipes . thanks
Old 10-02-2006, 11:39 PM
Mike,
You might try Stahl Headers. Try this link and if you have any questions, call them and talk to Jerry.
http://www.stahlheaders.com/Frame%20New%20RR.htm
Dan
Old 10-03-2006, 03:05 PM
C/Gas's Avatar
Also look into Hedman Headers. They angle out to hook up to a side pipe set up. The other headers mentioned will be high end $$ wise. Hedman's will be more reasonable. ( I assume you have a small block) C/GAS
Old 10-03-2006, 05:09 PM
larryblack's Avatar
Certified Lead Foot
Hooker used to make side mount headers that were direct fit.
I ran a set on a camaro once and they were excellent quality.
Old 10-04-2006, 06:09 AM
C/Gas's Avatar
Actually if you need more flow because of higher power, you CAN put up to 4.0" pipes UNDER 63-67 factory side pipe covers. Just needs a little spacing.
C/GAS............
Old 10-04-2006, 06:26 AM
reflog's Avatar
Have you tried getting comments from the guys on the Corvette Forum? There are a lot of them that run the headers with the factory side pipes. Surely one of them will know or has run the setup that you want to put on. Give it a try.
Steve
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 12:21 PM
Can't find headers for my 2002 GMC Sierra Mad Maggot Engine 11 09-17-2008 09:19 PM
making custom headers??? aztek_warrior Engine 2 07-11-2006 11:13 PM
Adding Side Pipes to 65 Corvette AMS3 Transmission - Rearend 1 09-26-2003 05:42 PM
80' Corvette Side Pipes cvwinton Engine 5 08-29-2003 06:42 PM
