Corvette MC: which reservoir is which - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2012, 07:56 AM
Vetteman61's Avatar
Last journal entry: Moving my Journal
I've been looking for this for an hour now. I'm just going to ask.
I have a Corvette Master Cylinder mounted to the frame on my 37 Chevrolet. It's a 4 wheel disc setup. Which reservoir goes to the front and which one goes to the back. I've seen conflicting pictures and I apparently can't think of the right terms to find this in a search.
Thanks,
Brandon
Old 04-12-2012, 08:53 AM
S10xGN's Avatar
Gotta love a turbo!
I'm pretty sure the port closest to the firewall (on a normal car) is for the front circuit, which would be the forward port on your setup.
Russ
Old 04-12-2012, 09:43 AM
Irelands child's Avatar
The largest chamber is the front - and on the 'vette m/c, the furthest from the mounting flange is the front brakes. There are universal m/c's with outlets on each side, but not all OEM styles. I ended up having to 'cross' mine for proper fit up.
The top line (looks as though it's just ahead of the cross member) goes to the front, the other that runs under and in that cast in notch), to the rears:
Dave W
Irelands child
Old 04-12-2012, 12:43 PM
Vetteman61's Avatar
Thanks !
Brandon
Remote Reservoir Alternative to '74 Corvette M/C hduff Suspension - Brakes - Steering 2 05-21-2011 03:31 PM
Remote reservoir positioning ? cboy Suspension - Brakes - Steering 14 03-15-2008 12:18 PM
Vacuum Reservoir Jag Daddy Engine 1 04-28-2003 05:28 PM
Brake Reservoir Question Jag Daddy Suspension - Brakes - Steering 3 03-31-2003 10:47 AM
Vaccum reservoir josh7681 Transmission - Rearend 5 02-19-2003 08:03 PM
