Corvette Rear in a 37 Coupe
I am considering putting a late model corvette IRS in my 37 Ford Coupe - is there anything special I need to watch out for? I am a bit conserned the Link bars are so short and am considering lenghting them for additional stability. Would this be worth the effort?
Thanks Clark |
moving to suspension forum , perhaps a few more answers
At the Bonneville Salt Flats, first gear is known as 130 mph. |
If you have decent fabrication skills ... it is not extremely difficult to do ... Or Progressive Automotive ... has a kit to do it ... http://www.progressiveautomotive.com/ |
Progress Pic's
Not much Progress - but here is the journal of my 37 Ford Coupe - Thanks for the interest
http://www.hotrodders.com/forum/jour...ournalid=47352 Clark Last edited by 37FordCoupe; 11-19-2006 at 06:33 PM. Reason: Forgot the Link |
If you do lengthen them you should know what you are doing so you don't screw up the geometry and "create" stability issues... Mark |
Clark |
Hey Clark,
The Cg will definitely be altered from the Corvette Cg but Roll Center is tied more into the suspension itself. You haven't said what your intentions are for the front suspension. This will have a direct input on Roll Center even more then the rear. Do you have the same plans for up front? Mark |
Mark Up front I am planning a drop spindle M2. Thanks for the feedback Clark |
| Corvette 68 Rear End Pinion Seal... | Mean@MeanMother | Transmission - Rearend | 5 | 06-08-2006 10:07 PM |
| 50 pontiac coupe want to use a s10 front clip and rear will these work thanks | JOHNNY M BROWN | Suspension - Brakes - Steering | 5 | 11-27-2004 07:12 PM |
| Is this '37 two door Chevy coupe worth HotRodding? | STATUTORY GRAPE | Body - Exterior | 6 | 11-08-2004 08:48 PM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
| 79 Corvette Rear | dstygar | Transmission - Rearend | 0 | 10-29-2002 03:55 AM |
