Corvette steering column loose - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2005, 06:03 AM
woody51's Avatar
Hi guys,
I have a 85 Corvette tilt column in my 46 Ford, has been great for a few years but now I can move the wheel from side to side about three inches and top of column is sitting to the left, Pulled it apart and tightened everything up but still the same. Think it could have broken the pivot knuckle but not sure how they should look or if they can replaced,
Any help appreciated as you don't find these things in wrecking yards here in "oz"
Old 01-27-2005, 09:09 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Are you SURE you tightened everything? Review this thread which discusses the common problem with 99.999% of the GM tilt column complaints.
Old 01-27-2005, 02:40 PM
woody51's Avatar
Thanks willys36 but they were the four bolts I tightened, The problem appears to be down further, I think where the aluminium part attaches the column. With it all apart and the four bolts tightened still can get movement, but to the left. The top assembly is actually leaning to the left and needs slight pressure to centralise it.
Old 01-27-2005, 03:54 PM
Wiki Edits: 21
Ouch! Sounds terminal. Probably a vaporized bushing in the body of the column. Sounds like your only option is a complete disassembly and rebuild.
Old 01-28-2005, 04:29 AM
woody51's Avatar
Thanks willys 36,
On further investigation I think the mount for the pivot knuckle might be broken I think I might just dump the whizz bang tilt column and replace it with a local General Motors Holden Column, No hassle and local parts readily available
