Corvette steering column... what is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2008, 08:09 PM
This is attached to the steering column on my '63 Vette. It has a cable going to it and there is a resistor attached. I'm replacing the steering column and I need to know what to do with this. It is about half way between the firewall and the under dash brace.
Thanks (hopefully, the picture is attached)
Old 01-22-2008, 09:27 PM
Vette steering column
The cable and resistor is to be connected because at the factory they did not want someone to ground the steering wheel with sweaty hand and get a shock....also so that the horn would have a ground and not affect the radio...all because fibreglass is not a good ground. Connect it to any metal part grounded to the steel frame....That is the way it was on my 54 Vette. ACE
Old 01-23-2008, 06:59 AM
Thanks for the information. I'm installing an Ididit column with a 7 pin connector. Can I use that connector as a ground and not worry about replacing the cable and resistor?
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
63 Corvette steering column frankenvette Suspension - Brakes - Steering 6 11-28-2007 06:58 PM
interior paint for steering column corvette dmx6 Body - Exterior 3 10-26-2007 07:17 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 03:29 AM
