Corvette Suspension - coil over shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2013, 02:20 PM
Hi everyone, again my car is a 56 studebaker golden hawk that I have installed '94 corvette suspension, a 454 big block chevy, and 6 speed camaro transmission.
My current project is to replace the transverse leaf suspension with coil overs for better adjustability and hopefully performance. My issue is that there does not seem to be alot of people converting their '94 corvette suspension, therefor I cannot find alot of specific coil overs designed for the corvette suspension. So my question is does anybody know of some "hot rod" coil overs that would work with my vette suspension or some more options I can explore?. The mounts look pretty standard so maybe somebody knows of a generic "chevy" coil over that would mount up ok? Thanks in advance for any help, if needed I can post pictures.
Thanks!
Old 10-27-2013, 02:52 PM
techinspector1's Avatar
Wiki Edits: 326
At the bottom of page 2 here is a list of coilover lengths center to center. Choose the one that will fit into your space....
http://www.qa1.net/tech/documents/Sh...UltraAluma.pdf
Old 10-27-2013, 09:23 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I have used the single adjustable QA1 aluminum body coilovers with poly mounts. If space is tight use the shock that requires a 10" spring. If more space is available the 12" spring unit should work.
I designed and built a double shear lower mount that attaches to the original lower shock mount and lower trailing arm mount. If you are interested in a part like that, PM me and we can work something out.
Regards,
Andy
Coil Overs or 2"drop springs with coil Over Shocks only. Leroy's 55 Suspension - Brakes - Steering 2 02-26-2013 09:31 AM
Coil Over Shocks YES or NO ? rja38 Suspension - Brakes - Steering 4 09-06-2011 02:51 PM
Coil over Shocks MISFT 1 Hotrodding Basics 4 03-12-2010 07:50 AM
Coil Over Shocks fred56 Suspension - Brakes - Steering 4 09-28-2006 03:26 PM
coil over shocks David G Suspension - Brakes - Steering 5 05-02-2006 05:02 PM
