corvette tach stuck on 1500 &vibrates - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2003, 06:50 PM
mikeweyman's Avatar
Last journal entry: 2 years later
Post corvette tach stuck on 1500 &vibrates
my tach is stuck on 1500 rpm running or not,it vibrates when you hit the throttle but stays at 15. could it be ground , blown circut board,it is the hei so it is electronic.clueless mike thanks
Old 03-13-2003, 08:21 PM
390xw's Avatar
Post
hey i dont know much but if its electronic the tach it might be a blown bulb not creating the rest a the circuit. if its a needle job here they get a lil heat and curl over touching the face plate then there stuck so it could be that good luck.
