Are you using the old style, filler tube intake?
The PCV valve is no problem, all you have to do is drill and tap a hole in your intake that opens into the lifter valley. The other problem which is a bit more complicated is what to do about the fresh air intake.
Vince |
Are you using an electric fuel pump? if so, you could do some custom fabracating and make a breather / oil filler out of some exhaust tubing a breather cap and cut a hole in the blockoff plate where the mechanical fuel pump went. Think about it, get creative, get a beer, sit down on a 5 gallon bucket and just look at it a while.
Gene |
no, no valley breather MI2600, but great way to look at it with the fuel pump idea, 57. I always think better on beer. I also look better on beer. also makes it easier to get those singles in the g-strings.
The fuel pump idea jogged a memory for me. I saw a street rod at a run a couple of years ago that had a fuel pump block off plate modified to function as a PCV breather. They drilled out the plate and tapped it for a 90 degree 1/2" bulkhead fitting. A hose connected to the bulkhead fitting and ran up to a fitting under the air filter. Took me a while to figure out what was going on, but after studying it finally figured it out. The owner saw me looking at it and came over, about that time I said "OH I get it". I complimented him on the idea and the work.
Vince |
| Recent General Rodding Tech posts with photos |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 24 | 02-16-2009 12:49 PM |
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
| 348-409 valve covers | Scuzzy | Engine | 2 | 08-08-2003 12:45 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
