Corvette White Smoke Out Exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 09:36 AM
My Corvette ran fine when I brought it home. I drove it around and got on it to see how it was. When I got home the coolant was bubbling out the radiator cap. The fan wasnt kicking on so I wired it straight to the battery to make sure the fan motor was good and it was. I filled the radiator up and drove it down the road and back. The engine was clearly overheating and I seen coolant bubbling out what looked like the valve cover but the header was right there where it was coming out so it could of been coming out there. The car had lots of white smoke coming out the exhaust except when I would rev the engine up it would stop and after it idleing a few minutes it would smoke again. This was not from condensation in the pipes this was a alot of white smoke that smelled funny. I think its a blown head gasket but want to ask around before assuming anything. Any advise on what it is.
Thanks guys
Old 03-09-2012, 09:43 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Coolant bubbling out of the valve cover??
If you don't see any coolant coming out of a crack somewhere, I would suggest a head gasket, maybe warped the head if you ran it hot, especially if aluminum, although it would be coming out below the headers, where the head meets the block, somewhere around the head mating surface. Do a compression test.
Semper Fi
Old 03-09-2012, 12:59 PM
T-bucket23's Avatar
Wiki Edits: 26
Head Gasket
Cracked head etc
Chet
327 with white smoke out of exhaust. inbredjedd Engine 9 08-19-2011 10:01 PM
white smoke in exhaust Steve 35 Ford Engine 1 02-12-2009 08:25 PM
Thin white exhaust smoke. DENCOUCH Engine 12 05-11-2008 12:45 AM
302 Engine thin white smoke out exhaust Rhettley Engine 10 04-09-2008 01:25 PM
