Corvettes and drag style oil pans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2003, 01:24 PM
New Member
Post Corvettes and drag style oil pans
Does anyone have any knowledge or experience using drag pan on a C4 vette? I want to use a 7qt drag pan on a 86 vette 383 stroker? Anyone have experience with ground / chassis clearances?
Old 02-20-2003, 05:57 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Measure from the block bottom rails to the oil pan bottom both front & rear. Most of the catalogs and manufactures give the depth of the pans, then you can measure before you buy. Dont forget you mite need another oil pump to fit the pan.
[ February 20, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
