cost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2004, 08:56 PM
badknuckles's Avatar
you talkin to me?
cost?
im getting new quarters for a 79 camaro what does something like this cost to have put on?
im not into cutting up my car i'll save that for the pro's.
btw i have my hood done and my roof done and doing good.
Old 06-18-2004, 11:45 PM
They are about 16 or so hours a piece to install, what is with no extra work like rusted wheel wells or that sort of thing. What the hourly rate is in NJ, I don't know. Around here it is about $65.00 and hour which would make it about $2,100.00.
Old 06-19-2004, 05:22 AM
BarryK's Avatar
Don't let the labor rate scare you to much as the rate in NJ is a lot less. I think the east cost is getting short changed on labor rate but thats another story.
You might look for a body man that does work on side at home
and you can probably cut the cost in half if you buy the materials so he doesn't have to run allover. With most bodymen if you do the painting thats also a real plus. There should be some bodymen close by on this site.
Old 06-20-2004, 08:19 PM
adtkart@aol.com
$65.00 per hour for body work? The people around here scream about $36-$42 per hour.
I would be looking for someone that can do it on the side.
Old 06-20-2004, 08:29 PM
Yep, and mechanical is about $80.00.
Old 06-25-2004, 10:42 PM
you talkin to me?
2100 dollars?
for that much i'll butcher it up myself.
the body shop next door is 50 an hour.
16 hours a piece?
there are rot holes in front of the back wheels they are about the size of a baseball.
Old 06-26-2004, 03:11 PM
GMW GMW is offline
you don't necessarily have to replace the whole quarter. If everything but the baseball holes is sound, just repair them.
Old 06-26-2004, 11:30 PM
adtkart@aol.com
If the rest of those panels are solid, I wouldn't replace the panels, just the damaged areas. You could use the replacement panels, or plain sheetmetal to make patch panels.
Old 06-27-2004, 12:36 AM
4lug39's Avatar
General rule of thumb is what ever size the rust through is on the outside it's twice that size on the inside. I just went and looked a friends. You should probable replace the QT, Also look at the inner fender and trunk/floor. Your rust problems look like they are more than likely going to affect those areas.
Just my two cents .
Old 12-15-2005, 11:45 AM
bigblockbill's Avatar
i'll do it for free just get the here doink
Old 12-15-2005, 05:41 PM
quarter panel
I have a 80 and for just the driver side panel i was quoted 350.00 just for the labor. Me bringing him a new quarter panel and having the back glass removed before i brought him the car.
