cost of boring an engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 08:37 PM
Last journal entry: Front suspension update
hi guys does anyone know how much it would cost me to bore out a 350 chev and put new oversize pistons? really i'm just trying to get an idea if i'm better off to get a long block and and junk yard engine and compile parts or bore the junk yard engine. local carquest quoted me a long block at $1300 with $300 core. thx
Old 11-12-2012, 08:49 PM
Its usually cheaper to buy it as a package. What type of pistons?
Old 11-12-2012, 09:17 PM
327NUT's Avatar
Not many good things have been heard about auto part store engines....Auto Zone, Car Quest or others. A guy near me with a '32 hiboy didn't want to go to the "trouble" of building his own and bought a long block from a NAPA store....BIG mistake!!!! ran like chit, smoked like a battleship, rings never seated, yada.....There's guys on here that buy the newer truck Vortec roller 350's from the boneyard and say they have good runners. I'm sure one of them will be along with more info on that.
Old 11-12-2012, 09:18 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
My local machine shop charges here in Kansas City...
Bore $25 per cyl
Hone $8 per cyl
But you want new pistons so they are going to have to press the wrist pin out
$7 each rod
$320
They will likely charge you labor to file fit your new rings too.
If you bring the shortblock they will likely charge you to disassemble and reassemble the rotating assembly as well.
They will charge you to rebuild the rods as well (something like $7 a rod if IRC), which is a great time to swap the OEM rod bolts with ARP bolts.
A long block for $1,300 sounds pretty cheap. You get what you pay for, and pay for what you get. Is this for a daily driver or performance?
If performance and installing new pistons, you really ought to balance the rotating assembly, $225.
Old 11-12-2012, 09:31 PM
BOBCRMAN@aol.com's Avatar
Plus clean block. plus crack check. plus r&r cam bearings/soft plugs.
Old 11-12-2012, 10:44 PM
thanks for the replies. i'm not planning on super high perfomance, i just want something reliable. what do you say about a company that bores 350s and sells them as long blocks for $950 + shipping? i forget the name.
Old 11-12-2012, 10:52 PM
here's the website: Chevy 350 engines - Remanufactured 350 engine, GM Chevrolet Crate & Rebuilt Engines
Old 11-12-2012, 10:57 PM
vinniekq2's Avatar
If you forget the name they probably are not worth remembering. A well build stock engine is not much cheaper than a hipo engine,quality parts cost money,good machining is not cheap.5 to 600 for a block to get machined is fair(clean/bore/square/deck/align hone/new cam bearings/new frost plugs) some people just wash the blocks and bore,nothing else
Old 11-13-2012, 06:03 AM
Banned
g.m. long block 350 1500.00
all new parts.
Old 11-13-2012, 06:15 AM
Last journal entry: 27
mine runs like a dream
doesnt use any oil
and zero smoke
i also get 26 mpg highway
Old 11-13-2012, 08:59 AM
I charge 125.00 to bore and to do it right is to plate hone is 125.00
Old 11-13-2012, 10:01 AM
doesnt use any oil
and zero smoke
where did you get it?
Old 11-13-2012, 04:07 PM
oriellys
good thing it cant read.
i guess it dosent know it is supposed to suck.......
Old 11-13-2012, 05:55 PM
oriellys
sounds like a good place to try. thanks. and don't YOU come teach mine to read!
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Cost for some engine and misc work SBCfan04 Engine 2 02-02-2010 08:48 AM
Boring a Go-Kart engine oldred General Rodding Tech 13 08-01-2009 06:26 PM
need assistance repairing a boring car with a boring problem ret_marine2003 Engine 10 05-17-2007 08:50 PM
boring out my engine 73monte Engine 4 12-11-2003 11:27 PM
How much does it cost to get an engine rebuilt? '54-Hunter Hotrodders' Lounge 13 02-14-2003 05:02 PM
