could it be bump steer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2007, 07:16 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
1978 Buick Century, yes, it's my Mom's car, when is driven straigth the car wanders to the sides and when cornering seems like somebody is helping turning the wheels from underneath, all ball joints, tie rods, bearings etc are OK, I had it aligned and was fine, tires and rims are new, driving it makes me sick like if was in a boat, any ideas what is happening? feels like bump steer but how come it suddendly appeared?
Thanks.
Augusto.
Old 04-04-2007, 08:47 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
My 59 does this----could be the 605 box.
But, also the alignment readout I got from the twits @ Sears
said that it was adjusted with 0" toe in. (s/b 1/8" total toe)
I get the wobblies predominately in long sweeping right turns @ 60+mph
So, I am thinking I have an actual toe-out while in motion, and the car cannot decide where it wants to go
That---and I am not real happy with the 605 conversion.
Anybody else got any ideas??????
Bryan
Old 04-05-2007, 10:33 AM
powerrodsmike's Avatar
Wiki Edits: 161
Did something in the box go away? It sounds like box adjustment could be too loose.
If that checks out I'd check the caster specs to see if the tech did actually check it.
Is your idler arm ok? Those can cause problems like that sometimes.
Later, mikey
BE different....ACT normal.
Bump Steer al_32_ford Suspension - Brakes - Steering 5 05-01-2006 06:19 PM
Power Steering conversion question / Bump Steer robin58 Suspension - Brakes - Steering 4 08-12-2005 10:02 PM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 09:15 PM
'30cpe- nissan rack and pinion, bump steer Markmc59 Suspension - Brakes - Steering 4 02-25-2004 08:52 PM
bump steer A40eh Suspension - Brakes - Steering 4 11-23-2003 04:01 PM
