Could heat damage my coil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 07:13 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
I installed a new msd dist. new msd wires.. new battery 8 degrees of timing runs great... almost perfect..
and then
it warms up and when it around 200 * it hesitates , misfires , backfires runs ruff when i give her goo goo juice . the coil im using is accel super coil cylinder shaped chrome job. ( i could do without the fancy shmancy) anyways its about 6000kms old maybe more . Could the heat be hindering or even damaging this coil? as well which is better oil filled or apoxy filled?
thanks again
billC
Old 09-03-2006, 11:50 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Your coil will get fairly warm when it's operating, I don't think that's going to cause your problems. Epoxy filled coils are usually used in high vibration applications.
Old 09-04-2006, 12:32 AM
fat50chevy's Avatar
New Member
If you post your question in the elec. section Doc will most likely jump on and help. He's great with that sort of problem, helped me a few times. He may want a little more info, like type of dissy ( points or small body HEI ). the type of coil I think you have (Oil Filled) I am told is better.
Old 09-04-2006, 10:28 AM
sweet thanks ill go ask doc and the rest of the electric minded folk lol
thanks again
bill
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
over heating delsman Engine 38 09-14-2005 08:32 PM
Push botton starter street rodder 1937 Electrical 4 03-17-2005 09:19 AM
Coil Failure after heat up green66 Electrical 2 07-27-2003 02:05 PM
