could my 700r4 be stuck in lockup?_ - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2013, 06:24 PM
59 wagon man's Avatar
my 700r4 lockup is controlled by a tci lockup kit .all it has is a pressure switch in the side of the tranny which activates a relay. most kits i see now also have a press. switch and a vac. switch also. my problem is no matter what i do even with a 350/-330 hp motor it doesn't seem to have the pep it sho ld
Old 04-25-2013, 06:52 PM
if it was stuck in lockup it would be like stoping a stickshift car while in gear. It could not be going into lockup...
Old 04-25-2013, 08:10 PM
When you step on the gas pedal lightly does the engine rev up like it's in neutral for a second before it starts to go accelerate?
Old 04-26-2013, 08:14 AM
no the car also feels like it is dragging a trailer behind it . once it is rolling above 70 or so it seems fine
Converting non-lockup 700R4 to lockup V8TEC Transmission - Rearend 7 09-10-2011 09:25 AM
700r4 Lockup lelshaddai Transmission - Rearend 11 08-04-2008 01:23 PM
700r4 lockup runn141 Transmission - Rearend 3 09-06-2006 06:40 AM
700r4 lockup hdbiker Transmission - Rearend 4 02-20-2006 12:52 PM
700R4 Lockup My31and37 Transmission - Rearend 2 10-18-2002 03:21 PM
