could it be the starter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 12:39 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok guys yesterday I had my old mans car&the battery light came on not shortly after all of the lights dimed so I pulled over&the car died.Had it towed home.Took a battery that I know is goood&put it in there&the lights came on strong I tried to crank her over&the started made a real weak waaa waaa waaa sound like it wasn't getting juice I've heard bad starters make this noise before.So I put in another good battery I just fully charged&tryd to jump the starter solenoid &same noise.I'm guessing its the starter but how could it of made the car die?btw all my connections are nice clean&tight.
Old 02-25-2011, 02:15 AM
vetteman2's Avatar
Take the battery to your local auto store and have it tested.
I might be the alternator
Old 02-25-2011, 02:34 AM
two cups of tea
Wiki Edits: 2
Did you miss the part that said I've tryd 2 other batteries?
Old 02-25-2011, 03:50 AM
EOD Guy's Avatar
With a known good battery, as you have stated, it's got to be a connection (dirty terminals) loose grn etc.... or a bad starter soleniod. I don't think a bad starter will kill the engine, do think a bad alt and a dead battery will. Not all batteries are created equal and I have learned over the years a battery that will light the lights may not have enough juice to turn the starter over.
Old 02-25-2011, 09:14 AM
vetteman2's Avatar
your 2 other batterys are junk
Starter help. Can you make a new starter old? Hogger Engine 2 09-21-2010 10:48 PM
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
Which starter do I have? mrl Engine 5 04-15-2007 05:52 AM
