could valve be stuck open - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2010, 08:24 PM
I just rebuilt topend on 86 Chevy half ton pickup 305 I changed valve seals I got it put back togather and started it up an now it smokes really bad got oil driping out exaust could I not could I not have rocker ARMs set right causing a exuast valve to stay open
Old 07-13-2010, 10:58 PM
sbctruckman,
This happens everytime you do a valve job on a block that has many miles. By getting the valves to seal causes the rings to "give up the fight". With better vacuum because the heads do not leak the rings allow oil to get "sucked" up into the combustion chambers and what you get is a smoker.
Sorry
Scholman(retired)
Old 07-14-2010, 04:33 PM
ScojoDak's Avatar
Mopar for life!
If the exhaust valve was hanging open, you'd have a "miss" symptom. Not only that, but if you adjusted the valves all the same way, then all the exhaust valves would be hung open. Then you'd definately know something was wrong. scholman pretty much nailed the cause.
Old 07-14-2010, 08:06 PM
68NovaSS's Avatar
Wiki Edits: 9
It could also be valve guide seals, worn guides, broken ring.
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
Stuck valve? Ford T-bird anthonyc1 Engine 4 11-04-2008 06:55 PM
stuck valve problems hammerhead Engine 7 10-21-2008 10:33 PM
Stuck intake valve jdoole3803 Engine 2 08-26-2006 04:11 PM
