could we talk some one into doing a gm auto trans rebuild tutorial? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 10:00 PM
I would do one but i dont know how to rebuild one or even how it works.... I would pay some one to show me but everyone in oklahoma is smug about knowing something someone els does not. I have plenty of gm transmissions laying around that ummmm have seen better days. i would even do the work and post pictures if some one could give me a walk through. or maybe the best advice for a novice as far as dvd's books??? This is somthing i would love to learn, I want to learn any thing any one is willing to teach. I will have to buy new tools though as mine got lifted off my truck box and all. i guess a big red rolling box isn't just inviting to a thief. never will i take my tools with me to help some one
Old 01-18-2011, 05:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ron Sessions (sp?) has a book out that's been favorably reviewed by some here. I used a GM factory Unit Repair/Overhaul manual to do my first TH350 &400 trannys.
Jakeshoe has a number of walkthroughs that he's posted online for various GM trannys, you might do a search for them- they include photos.
Old 01-18-2011, 04:19 PM
wow there's alot more info than i expected!!!! Thanks and i kinda have a grasp on the functions inside a tranny.... now to gather info on the 700r4 and the 4l60E and decide what one to try first cause i have several, 3 TH350s,2 700Rs,1 TH400, 2 4L60s. one with the big black box on the side and one w/o. and a buick TH 350 on a buick 350-2,the trannys supposed to be good but the engine is froze up. and a few good trannys lying around.
So... I have plenty of patients to practice my hands on.
Old 01-18-2011, 05:09 PM
I may be willing to do something like this.
Old 01-18-2011, 05:13 PM
Geez you don't need a tutor just to rebuild automatic transmission,just a good book will do and the right tools.
Old 01-18-2011, 05:35 PM
LATECH's Avatar
Not to mention there is a gazillion dvd s out there that show you how to rebuild and make performance upgrades
Old 01-18-2011, 05:56 PM
I think now with a good book and the advice i found from Jakeshoe I may be able to pull this off. They are alot less complex than i thought. people act like its some magic machine but all it really is is a hydraulic pump really with a few twists. Friday or Saturday im going to sit down with a book,my laptop, and a transmission and pull one apart. If its easy enough just to take it apart and put it back together then i will get a rebuild kit and build my first transmission.
Old 01-18-2011, 05:57 PM
Hey transbuilderguy!
do you mind if i pick your brain after my tear down?
Old 01-18-2011, 06:15 PM
if you wanna learn the basics start with a th400 is one of the best to learn with. its drum to drum all planets in rear kinda hard to mess it up other than snapring locations and bearings and washer placement but yes you can picl my brain.
Old 01-18-2011, 06:42 PM
awsome
i saw somthing about assembly grease .or vasoline. What will i need this for?
Old 01-18-2011, 06:51 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Regarding a formal tutorial, I would recommend sketching out the outline of a wiki article: basic questions, headings, maybe a relevant link or two, etc. People can then come along and fill in the blanks.
Old 01-18-2011, 07:15 PM
you can use petrolueum jelly. trans gel is what you are referring to itcomes in green and red I like the green it does a good job of holding stuff together during assembly also.
Old 01-18-2011, 07:20 PM
Cape Cod Bob's Avatar
Try a th350 first. I did my own following Ron Sessions book tp the letter/. Do all nhe says and if you aren't sure or it don't seem right then post your problem on here before going onto the next step.
That is how I did mine and I had lots of help from members here incliding pictures showing me better suots of procedures then the book shows. It is running fine.
Old 01-18-2011, 07:39 PM
Thanks
I think ill do that i have plenty of th350s. not to go against what you said transbuildguy but i have more of them lying around just in case something goes terrably wrong. I only have 1 th400 left
Old 01-18-2011, 08:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are cheaper parts kits to do a TH350 than the B&M Transkit #30229 at <$200, but it does contain full instructions.
I used a Transkit in a Pontiac TH400 that was installed behind a 455 in a '65 Tempest wagon and it held up fine. Slicks and posi (of course), no trans brake on a prepped track.
The b&w photos supplied in the instructions vary from good to down right crappy in some cases, but w/the photos available elsewhere it's not a real issue.
Some builders will use different frictions and steels, depending. But as I've said, I had no problems out of the one I did.
I brought this up mainly to let you know there are kits w/instructions included. I don't know of any other kits that do this.
904 torqueflight rebuild tutorial ? MOPARINMYCAR Transmission - Rearend 12 11-10-2010 06:01 PM
350 rebuild- northern auto parts list critique whiteshadow Engine 8 09-25-2010 06:48 AM
Holley 4160 rebuild tutorial online? Chefasaurus Engine 9 06-20-2009 10:47 AM
Auto tranny rebuild - websites? asennad Transmission - Rearend 1 12-22-2005 02:27 PM
Ford Auto Trans Rebuild Videos Online! macx Transmission - Rearend 0 05-18-2005 12:46 AM
