Count the bolts??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2002, 02:12 PM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Question Count the bolts???
I have always heard of 10 bolt and 12 bolt GM rear ends, but the one I just got is from a 87 IROC and has 9 bolts on the inspection cover, and 8 bolts on the ring gear. Also what do you measure to see if it is a 7.5 or an 8 etc. the outer diameter of the ring gear, or the bolt pattern on the ring gear???
<img src="confused.gif" border="0">
Old 10-21-2002, 08:27 PM
BOBCRMAN@aol.com's Avatar
Post
you measure the back side of the ring gear where it bolts to the carrier, it will measure between 7 1/2- 7 5/8 in. the term 10 bolt and 12 bolt rears applies to rears that were built in the sixties and seventies and don't always apply to newer cars. 10 bolt cover had a 10 bolt ring etc.
Old 10-22-2002, 06:17 AM
Post
I found a web site that listed the rear-end. It is a Borg Warner 7 3/4" posi. Does anyone have gears for this to sell?
Old 10-22-2002, 03:21 PM
Post
Actually you measure the biggest area of the ring gear, the side that faces the pinion.
You have a borg warner 9 bolt, ring and pinions for these are hard to find and only a limited selection of ratios is available. I hear the 9 bolt is stronger than the 7.5 and 7.625.
Old 12-06-2002, 09:25 PM
Post
What ratio are you looking for? I have up to 4.10 ratios available. All the information is at www.9bolt.com
Miles
Old 12-11-2002, 05:00 PM
Thumbs up
[quote]Originally posted by BOBCRMAN@aol.com:
<strong>the term 10 bolt and 12 bolt rears applies to rears that were built in the sixties and seventies and don't always apply to newer cars. 10 bolt cover had a 10 bolt ring etc.</strong><hr></blockquote>
Thanks. That's good to know.
