Originally Posted by Grey1961
Is running a driveline centered parking break a viable option I have heard of them but never talked to anyone that has used them could you set up a 10 bolt 8.5 chevy for say under 200 bucks...
also is a line lock a safe option for a parking brake? also heard of people doing this but not sure how safe it is cause if you loose line pressure your outta luck...
Both will work but I prefer to use the OEM parking brake system. Both depend on hydraulic pressure...
oh one other thing does a brake booster need manifold vacuum or ported vacuum from the carb or does it matter?
General Motors uses manifold vacuum....
As one of the Moderators here.....I would like to
WELCOME YOU HERE....
DEUCE.......
