A Couple of Minor Problems in Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2006, 05:19 AM
reflog's Avatar
Some time ago I purchased an EZ Wiring Harness for my 32. I decided that I needed to install it this spring as I was getting more electrical problems than I needed from the old system (hand made). I have everything wired up and all seems to be OK except I am not getting power to the electrical choke and my Voltmeter shows nothing.
Does anyone know which circuit handles the electric choke on the EZ harness? I pulled all of the fuses that I thought I would not need and EZ doesn't tell which circuit runs the choke wire. I need it so the choke will pull off.
Secondly, the EZ instructions are not real good when it comes to wiring the alternator to voltage regulator. I have the old system, 2 wire with square plug. Instructions show wire to field and #2 on the regulator off of this square plug feed. At the regulator they show Alt Excitor wire going to #3 and #4. These two are tied together. They then stop their diagram and do not tell you where these wires go from there. Mine simply goes back into the fuse block. Is this wrong??? If so, where do I run this excitor wire from regulator and then back to what other point from that terminal?? On the gauge setup they show the ground wire and a simple gauge power wire coming from the harness. This gauge power wire is supposed to serve as power to the Volt gauge to show charging but it is dead. I know it has power as the fuel gauge works and it is wired together to feed power to the gauges. Temp and Oil Press are mechanical. Any ideas????
Old 05-05-2006, 06:05 AM
302 Z28's Avatar
Easiest thing to do about the choke is just run it from the field terminal of your alternator. You can power a relay from the field terminal and run 12v supply through a set of normally open contacts of the relay. This has the advantage of the choke not being energized until the engine is running.
I assume you have Ford system with the old style regulator.
Stator wire from alternator goes to "S" terminal of regulator
Field wire from alternator goes to "F" terminal of regulator
Battery wire from alternator goes to "A" terminal of regulator and also to battery+ (this wire needs to be a heavy wire, minimum #10 awg. It can come from a central point that is fed from the battery + post, or directly from the battery + post)
Alternator and regulator both need to be grounded.
For additional information go online to www.painlesswiring.com and download one of their manuals.
IMO, I would do away with the old style regulator and go with an internally regulated alternator. It is a much simpler system.
Vince
Old 05-05-2006, 07:24 AM
reflog's Avatar
302/Z28
"I assume you have Ford system with the old style regulator."
I should have been more specific. I am running GM here. Column and all is GM. If EZ were a little better to deal with on the phone I would call them and ask them to advise me which circuit the choke is on but when you call them they are always busy and they take your phone number and say they will call you back. If they only put a description of the circuits in their install book it would help. My car does not have power windows, antenna, etc. No need to keep these circuits hot so decided not to cut the wires but just disable them and store them behind the kick panel on drivers side. That way, if anyone else ever wants to add these options, they can. Rather than running a new wire to feed the choke, would like to simply find out which fuse runs it, plug it back in and it is ready. I can plug a fuse into all the circuits, one by one and leave the key on to determine which it is but I thought maybe someone had run into this prior. My main problem is the volt meter not working. I have to find that problem or I'll never know whether or not the system is charging. Thanks.
Old 05-05-2006, 08:07 AM
302 Z28's Avatar
Understand, but you want to avoid a situation where your choke is hot with the key on and the engine off. That way you can do whatever you need to do with the key on, but the choke will be operating from a cold position and will not receive 12v until the engine is running. That is the proper way to wire an electric choke.
Pick any 12v fused source that is open to you. On one side of a normally open set of relay contacts connect the 12v source. The other side of the open contact is wired to your choke. The relays coil gets powered from the field terminal of your alternator.
Vince
Old 05-05-2006, 03:23 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
302Z28 Is Right on about the choke! That's EXACTLY the way you want it.
About your Volt meter..Simple..Black wire to hard ground, And Power Wire to ANY switched source in the harness/Fuse buss..That's it..No special wiring needed.
You can hook a Voltmeter ANYWHERE Parallel to the battery, as opposed to an AMP Gauge which must be installed in SERIES between the load and the source.
Doc
wiring schematic - '80s Caprice Engine compartment gtofloyd Electrical 3 12-08-2003 10:58 AM
Distributer/alternator Wiring Help DIECASTFIREBIRD Electrical 1 12-05-2003 08:24 AM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
Painless wiring kits I_3putt Electrical 17 10-27-2003 02:39 PM
The BEST book on wiring Madd Syntst Electrical 2 07-01-2002 05:04 PM
