No problem, Brian. If that tack strip is still solid and will hold staples, you can still use it. Don't worry about masking it off, just paint right over it, but don't sand blast it.
The center bow area on the top itself will have a pocket glued to it that holds the metal strip, and that gets bolted to the bow. See the holes in the bow? That's where the bolts go through the bow to attach the metal strip. The bolts go right through the cloth pocket and into the metal strip. Each hole in the bow should have a corresponding threaded hole in the metal strip. This is the last thing that needs to be attached in the whole process.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Thanks Dan, I guess that is the 64 thousand dollar question, will that tack strip hold staples? I think it will, I mean getting all those staples out was a BEACH they were holding damn good. If it is just a matter of replacing it, I am there, I will take the time and money to replace this very important part of the project no problem. But I am concerned with the new rubber like material not being as good to work with, not "taking" staples as good.
What do you think? How do the pros and cons weigh out in your opinion? Brian |
If the rest of it is like what's in the picture, I'd use it just the way it is.
Brian |
| Recent Interior posts with photos |
| Couple Of Questions | monzter | Engine | 10 | 06-07-2009 03:39 PM |
| Couple of questions..... | sexypizzaman | Engine | 8 | 06-04-2009 05:04 PM |
| couple more questions | CamMan | Engine | 5 | 12-12-2003 06:41 AM |
| couple questions. | 72superbug | Electrical | 3 | 08-18-2003 08:54 PM |
| Couple of questions | Scuzzy | Body - Exterior | 2 | 12-10-2002 09:14 AM |
