couple of ? on primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2010, 05:06 PM
im using PPG shopline products
J P 202 2k primer surfacer
J R 506 medium reducer
J H 301 2k undercoat hardener
car was down to bare metal, i put on two coats of epoxy, then sprayed two coats of primer on and sanded it with 150 grit. i mixed to what the tec sheet said. 4 parts 202 1 part reducer 1 part hardner. i would like two spray 1 or 2 more coats, the tec sheet also says for a high build application the reducer may be cut to 1/2 part. and as a spray filler 4 parts 202 and 1 part hardner. what is the difference between the two , which one should i put on, the body will only have little bondo ( FILLER ) on it
also i bought a new hood (ford tooling ) it came black can i just scuff it up with a scotch pad then prime it. thank you all in advance for your in put
Old 09-11-2010, 05:02 AM
BarryK's Avatar
You can scuff the ecoat with. 180 to 320 (don't break through the ecoat.) for the urethane primer application, would not go much finer.
For a sealer coat you can scuff up to a gray scuff pad.
You do not need or want a high build here, use the regular build formula and that will give you was they call an industry standard type fill.
Spray a few coats and block and do again, you don't need or want a pile of mils on a new panel.
Primer @ BC question henny496 Body - Exterior 1 04-03-2007 07:23 AM
Urethane primer and body filler Lator_Gator Body - Exterior 23 01-08-2007 02:15 PM
SPI primer and clear, a product review, and a "how not to" lowROLLERchevy Body - Exterior 26 12-21-2006 06:40 PM
using primer question AdamZx23 Body - Exterior 21 02-16-2005 10:53 AM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 04:55 AM
