Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Couple Of Questions
Old 05-31-2009, 08:44 PM
monzter monzter is offline
Couple Of Questions - 350 Chevy for a Jeep
Here´s the thing guys, I own a Jeep Wrangler Yj 1987 on 38" tires with 4.10 gears, it has a Chevy 350 from a 1973 Chevy C-10 and is probably around 150 horsepower, it has a Edelbrock Torker Intake manifold and a 4 barrel holley 600 cfm carburetor, i am assuming the heads are stock with probably 1.72" Intake valves and also that the camshaft is a stock one. There are headers on the engine. The transmission is TH-350 with shift kit and i assume the converter is stock one and the transfer case is dana 20.
So here´s the thing, i have in the garage slightly massaged 3932-441 gm heads with 1.94" Intake valves and a thinner 0.015" head gaskets to bump the compression up a bit, I also have the Crane Powermax 272/284 - .454"/.480" lift ( 216/228 @ .50" ) Camshaft on 112 Lsa that i am thinking about to put in the engine, the ignition is a slightly modified Gm HEI.
How do you guys think this would work out, It would be grate if this would get me around 250+ horsepower for my Jeep.
Best Regards
