Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Couple Of Questions
Old 06-01-2009, 12:25 PM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by monzter
Here?s the thing guys, I own a Jeep Wrangler Yj 1987 on 38" tires with 4.10 gears, it has a Chevy 350 from a 1973 Chevy C-10 and is probably around 150 horsepower, it has a Edelbrock Torker Intake manifold and a 4 barrel holley 600 cfm carburetor, i am assuming the heads are stock with probably 1.72" Intake valves and also that the camshaft is a stock one. There are headers on the engine. The transmission is TH-350 with shift kit and i assume the converter is stock one and the transfer case is dana 20.
So here?s the thing, i have in the garage slightly massaged 3932-441 gm heads with 1.94" Intake valves and a thinner 0.015" head gaskets to bump the compression up a bit, I also have the Crane Powermax 272/284 - .454"/.480" lift ( 216/228 @ .50" ) Camshaft on 112 Lsa that i am thinking about to put in the engine, the ignition is a slightly modified Gm HEI.
How do you guys think this would work out, It would be grate if this would get me around 250+ horsepower for my Jeep.
Best Regards
You need to look and see what heads are on the engine, it is unlikely that a stock 350 has heads with 1.72 intakes.
The 441s are no improvement over stock 78 heads, they are large chamber low compression heads with the added disadvantage of not having hardened valve seats for unleaded fuels.
Bogie
