Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Couple Of Questions
Old 06-01-2009, 03:14 PM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
he also need to find out where the piston is at TDC before he goes committing to a specific head gasket thickness, using a thinner head gasket to get higher compression is the least advised method as it changes your quench, which you will want to be around .036-.045
