Hotrodders Bulletin Board > Tech Help> Body - Exterior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 12-05-2002, 11:15 AM
Scuzzy's Avatar
Scuzzy Scuzzy is offline
Certified Cruck Lover
Post Couple of questions
Hey all! just a couple of quick inquiries. First off, Where can I find a relatively inexpensive cowl hood that uses stock latches (either steel or reinforced fiberglass) for a 1980 el camino? The other question is anyone know a good way to get bullet holes out of sheet metal? I have a 1960 El camino and some ....lovely person stole it and put 6 decorations down the passenger side rear quarter..........well at least it was recovered.....
they go all the way through the first metal wall and they got stuck on the interior of the passenger side bed wall.... so I have entrance and exit wounds
  #2
Old 12-05-2002, 02:51 PM
chevellesrule71 chevellesrule71 is offline
Post
weld in sheet metal behind the holes ,grind smooth and then fill the small surface depth with fiberglass and sand, i wouldint use bondo, not nearly as strong as fiberglass. As for the hood, probably summit racing, or jegs.com, just search for chevy parts on the net, there's a billion of them. good luck, Matt
Old 12-10-2002, 10:14 AM
Scuzzy's Avatar
Post
will the fiber bond to the metal? someone has told me it wouldn't
or at least wouldn't bond well
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
