Couple of questions about 350TBI swap - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 06-30-2013, 08:29 PM
Hello,
Currently reworking my harness before my swap. Engine/trans/harness are '93 Buick Roadmaster (same as Caprice).
~ What do I do with purple/white wire from C9, going to crank fuse? What is "crank fuse" anyway?
~ The engine has 2 temp sensors, 1 on top of the intake manifold with yellow and black wires, the other on the driver side of the block with green and green/white wires. I think the one with yellow and black wires is for the PCM, the other one for the stock temp gauge. Can I use that block side sensor for my aftermarket gauge? Should I use my aftermarket sensor in that location for my aftermarket gauge?
Thanks!
Old 07-01-2013, 04:03 PM
Tim C's Avatar
The crank wire needs to be hot when the starter is engaged. It tells the computer you're cranking the engine so it will pick the right fuel and timing for easy startup. I tie that wire to the wire that kicks out the starter solenoid. The sensor in the intake is for the computer the sensor on the head is for temp gauge or electric fan if equipped. It will not work for aftermarket gauges usually but you could use the wiring since it is all wrapped up in the loom as a neat way to run the gauge wiring into the car.
Auto guide sucks
Old 07-01-2013, 07:10 PM
Thanks Tim!
For a guy with a Mustang by your name, you know your Chevy stuff!
Old 07-01-2013, 07:15 PM
Tim C's Avatar
Haha. I don't even have the stang anymore. My hotrod is a 67 fairlane.
I swapped Chevy TBI from an 89 k1500 onto the 351m ford motor in my rock crawling 78 f150. I'm also a mechanic by day lol.
Auto guide sucks
Recent Modern Electronic Engines posts with photos
Couple of questions ashman Engine 4 04-22-2010 10:30 PM
couple questions chevythmpr Engine 6 11-10-2009 01:37 PM
Couple of questions..... sexypizzaman Engine 7 06-04-2009 06:04 PM
305tbi to 350tbi (or carb) vortec swap enduro54 Engine 3 05-12-2009 09:44 AM
Couple of questions... unstable Body - Exterior 6 03-28-2003 06:23 AM
