Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Couple Questions brake related
Old 03-25-2013, 05:50 PM
455olds's Avatar
455olds 455olds is offline
The brakes may be dragging if the pushrod between the master and booster is the wrong length. I had to get an adjustable pushrode from a junkyard for mine to work right. If the rears are drums one side is probably too tight and needs adjusted
