couple of quick questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2010, 07:10 PM
untchable502's Avatar
ok just have a couple questions hopefully someone can give me some insight...has anyone ever put a true dual exhaust system on a 3rd gen camaro...2nd question..looking for a set of vortec heads...what do i need to look for and where is a good place to look...does anyone have a set they want to sell??...last question if you have read my "noisy 350" thread you will know i have a phantom noisy after a cam swap i have done every thing from changing rocker nuts to adjusting valves...finally took a stethescope and reved it up and narrowed the sound coming from the #1 intake runner on manifold which leads my to believe something with that valve....spring maybe??? any other ideas?? thank you
Old 09-09-2010, 08:41 PM
Overdriv's Avatar
I haven't.
060, the last 3 digits of the casting number....junk yards.
If I remember right you installed a Comp hydraulic Extreme cam. Now it's noisy and you think something is wrong. If your pre-load is correct on the lifters there is probably nothing wrong.
I have an Extreme cam in a 406 that is noisy. Also, if you use cast aluminum valve covers, they will make the noise seem louder
Run it and enjoy it.
Old 09-09-2010, 11:44 PM
ericnova72's Avatar
More for Less Racer
Some incorrect info in the above post^^^
Last 3 digits to look for on true Vortec heads are 062 and 906. 060 is the last 3 digits of the service part number from the parts book listing, not a casting number.
Cast aluminum valvecovers will dampen the noise, not make it seem louder, compared to stamped steel.
Old 09-10-2010, 11:09 PM
Overdriv's Avatar
That is correct. I got my numbers mixed. Thanks for the correction.
It has been my experience that cast aluminum valve covers will amplify the noise. Your experience may differ than mine obviously.
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
1994 Saturn SL2 - few quick fix up/maintenance questions KoTT Engine 0 09-17-2009 03:24 PM
Putting patch panels in truck bed, couple questions ChevyJim Body - Exterior 20 02-10-2006 07:38 AM
Some quick fiberglass questions... 94max Interior 5 06-30-2003 04:21 AM
Couple of questions Scuzzy Body - Exterior 2 12-10-2002 09:14 AM
