Couple of tranny questions(GM) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2005, 07:51 PM
Mike_82's Avatar
Hi. i have a 3400 lb pontiac bonneville. i put my street stock engine, and Monte SS rear in it with 3.73's & posi. i am also gonna change the tranny. should i use a 200R4 or a TH350? i dont care about gas mileage. i just want whats gonna be best for performance. do you think either trans will hold up to the power of my engine?
engine specs:
.060" over 350.
11:1 compression
TRW Forged Dome Pistons
New stock rods and crank
Fully ported Camel Hump heads with 2.02/1.60 valves and roller rockers.
Edelbrock Torker 2 intake
Crane Energizer 302 cam(246 duration .500" lift)
Holley 650 CFM carb
1 3/4 headers, 4" exhaust from header, about 4 ft long. gotta come up with something different than that. lol
Thanks Alot.
Old 03-22-2005, 12:11 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
My choice is the 350 but your going to have to put some parts in it to get it to hold up. Red friction plates, shift kit, convertor, and case hardened sprag race.
Old 03-22-2005, 12:44 AM
jakeshoe's Avatar
The 200-4R will require some mods to live reliably. Would not be real cheap...
The deeper ratios COULD help...
The Th350 will hold up with minimal mods.
Red friction plates are not required...
A stock type tan Borg Warner friction works well. I have one Th350 using a stock 4 clutch direct with the BW's and running 10's in the 1/4 in a 3600 lb Camaro. 2 seasons so far.
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
Ever have this happen to your tranny? Help BudLight Transmission - Rearend 6 06-12-2004 09:21 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
