Coupling S10 tranny to SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2005, 06:59 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Hello,
I have question. I know that some of the 4.3 V6 S-10's came with standard transmission. Is it possible to hook that tranny up to a 267 SBC? Engine will me mostly stock so it shouldnt have a lot of power, and rear end will also be out of an S10 (maybe).
Thanks,
Mike
Old 06-01-2005, 11:14 AM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
Yes it is. I run an NV3500 5spd from a 99 4.3l S10. It's a 1 piece tranny without a removable bellhousing. It has an integral slave/throwout bearing that slides over the input shafts collar, so there's a stainless braided line coming out of they bell that must be cut and modified to connect to a regular double flare style threaded clutch master. The 95-earlier trannies use the old stlye clutch-fork/throwout bearing with an external slave cyl. I use an early smallblock 168 tooth internal balance flywheel, with a 77 chevy 4x4 4spd clutch/plate (10 or 11) spline. I have run the big truck stagerd bolt starter, but it was touching the frame slightly, so I went with an 88 vette gear reduc. starter that I got used. That packed it in, so I now have a new 88 4.3l staggered bolt Wilson rebuilt, that has outlasted the warranty it came with, and has no probs. cranking an 11;1 smallblock. The trannies are pretty tough, But after 3.5 years,2 diffs, and countless U-joints and rear tires. I finally took out my 1-2 syncro.
At V8S10.org we are just talking about starting a new forum for people who are swapping S10 frames, and other S10 parts into other vehicles, as we know of a lot of people who are taking advantage of the size, strength, and interchangability of these little econo-trucks
Sorry for pluggin' another site
Old 06-01-2005, 08:49 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I had the same trans in my old '93 2wd full size. It held up for quite a bit of heavy use. The factory one tossed the 1-2 syncro at about 120,000 miles. And, I too had a problem with u-joints. It should be a decent bolt-in (remember, I said should be...) into just about any car. All you'll need is a big hammer and some duct tape...
In a while, Chet.
Old 06-01-2005, 09:12 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Well I really want the car to be standard, although there's not much space in a model T. Its either the S10 tranny or a Saginaw. Price comes first (I want CHEAP) and performance second. I've never done this so I'm hoping for a cheap and easy swap.
Mike
Old 06-02-2005, 06:21 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The main answer to the main question in this thread:
Yes the 4.3 V-6 shares the same bellhousing bolt pattern as the V-8 engines (so does the 200 and 229 V-6 engines for what it's worth).
Old 06-02-2005, 10:42 PM
So does the Cosworth Vega 4cyl. and 3L marine 4cyl. and toyota's V8 nascar motor, and chev big blocks, and straight 6's and Gen 3's, SB2's.
Old 06-03-2005, 09:19 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Thanks guys, how about performance? Should it move a little T along nicely?
Mike
Old 06-03-2005, 10:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
========= not the new 4200 straight 6 cylinder engine from GM. You probably knew that.
S10.....tranny swap. poncho62 Transmission - Rearend 5 03-26-2005 05:33 PM
Corvette LS6 and tranny coupling Brandotheamazing Transmission - Rearend 1 10-13-2003 03:08 PM
tranny help for my s10 speedracer0006 Transmission - Rearend 1 10-03-2003 02:10 PM
outting a sbc 350 back in with tranny already in car tips LoudMalibu Engine 16 02-15-2003 05:41 AM
Tranny question to my sbc BillyBob1950 Transmission - Rearend 1 01-24-2003 02:49 PM
