Covair Steering Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 09:56 PM
grapro's Avatar
Last journal entry: Out in the Sun
Covair Steering Box
Does anyone know where I can get a bearing # 1645 for a covair steering box. Preferably in Canada if possible THX.
Old 04-02-2007, 05:33 AM
Try Clark's Corvair Parts , they've got just about everything for Corvairs.
Old 04-02-2007, 08:35 AM
grapro's Avatar
Clarks
Tried Clarks they only had one in stock need another one recall seeing someone have one on the web can't remember.
Old 04-04-2007, 10:02 AM
Have you tried the Corvair Underground ?
Old 04-05-2007, 09:44 AM
powerrodsmike's Avatar
Wiki Edits: 161
Have you tried a bearing supply house like Motion industries or Applied Technologies, (king bearing)?
https://www.motionindustries.com/mot...p/mi/index.jsp
Motion is owned by the same company that owns NAPA and they have locations in Canada.
I always try the local bearing places for stuff like that. If the bearing has a number stamped in it, many times it will interchange to an off the shelf unit. Search by dimension if you have a good way of measuring the ID, OD, thickness and type.
Check with mullins also, I'll bet they have some sources.
Later, mikey
BE different....ACT normal.
Headers hitting power steering box topdogger Engine 10 02-26-2007 09:48 PM
Steering box removal? coda618 Suspension - Brakes - Steering 3 12-08-2006 06:45 PM
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 05:16 PM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
