Cover for the ugly ford solenoid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2013, 05:05 PM
Does anyone make a nice cover for those ugly looking Ford solenoids? I have a smoothed firewall in my 55 Chev and had to hide that eyesore from view but it makes for a royal pain if you ever have to service it...so I'm thinking of relocating it higher up on the firewall but would like to find a nice plastic or aluminum cover that will surround it? Surely someone must have made a cover to hide these things? Anyone know of a manufacture ?
Old 03-08-2013, 07:12 PM
ogre's Avatar
the 'Duracell Project'
move it.
why would you have a ford solenoid on a chevy any how?
a shaved firewall requires a shaved wire harness
Old 03-08-2013, 07:21 PM
EOD Guy's Avatar
I've used something like this to hide ugly things brfore........
New Aluminum Project Box Enclosure Case Electronic DIY 110x92x55mm L w H | eBay
Old 03-08-2013, 07:58 PM
sedanbob's Avatar
You could make a cover out of fiberglass. Cut some cardboard, tape it together, maybe leave the bottom open for your wiring. When you get the shape/size you want, tape it to a large piece of cardboard covered everything with aluminum foil - wax the foil so the fiberglass will release later. Mix up some resin, brush it on the foil covered cardboard - cover it with fiberglass mat - dab on more resin - more mat, more resin. When you have about 3 layers, let it all set up. Peel it off the foil, trim the edges, but maybe leave a flange to screw to your firewall. Sand it smooth - use body filler to fill-in and smooth - paint. It really isn't much harder than that. Good luck.
Old 03-08-2013, 08:21 PM
Originally Posted by ogre View Post
move it.
Trust me...all of my wiring is hidden.
I'm using the solenoid to keep the heat of my large tube stainless header from killing my hot starts but the solenoid was mounted down low behind the passenger side front body brace and it's a ***** to get at once the front clip is all installed. Now that I'm redoing the motor I an thinking of relocating it out to the top edge of the toe board where at least I can get at it if needed. It'll then sit just below the smoothed firewall and If I make a cover for it, nothing will be visible but it'll still be accessible.
Thinking that making one from glass is a good idea. Thanks for that tip Sedan Bob.
Old 03-09-2013, 06:59 AM
carolinacustoms's Avatar
Automotive Extraordinaire
I had a random thought looking at your picture, I don't know how it would look but I thought I would mention it. How about cutting the end off of a valve cover (say 3-4 inches long)? Something similar to the one on the car or just a plain steel one that you could paint to match the car? You could use stainless screws to hold it in place and it should give enough room to hide the solenoid with almost no fab work. Again just a random thought.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
Trucknut (03-12-2013)
Old 03-09-2013, 10:53 AM
RWENUTS's Avatar
Try these guys for an adaptable cover.
Custom Car Club Plaques from O'Brien Truckers
Old 03-09-2013, 10:54 AM
sedanbob's Avatar
Kelly
That's a clever idea!
The Following User Says Thank You to sedanbob For This Useful Post:
carolinacustoms (03-09-2013)
Old 03-10-2013, 10:44 AM
ogre's Avatar
sedanbob has a good suggestion. wrap it in foil and glass it.
Old 03-10-2013, 11:01 AM
malc's Avatar
Born To Be Mild
Hid mine.......................in the trunk.
I made the aluminum cover when it was in a different location,
did have a cover too.
Old 03-12-2013, 01:32 PM
70Caprician's Avatar
I think that solenoid is kind of cute, myself...
(Got one in both my '70 Caprice and my '71 Thunderbird, proudly displayed on the inner fender panel.)
Old 03-12-2013, 07:41 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
There are some folks on this site that say the Ford solenoid helps prevent "starter heat soak". I am not convinced. I have never heard a good explanation.
The other reasons for the Ford solenoid are 1- The main cable to the starter is not energized except during starting when the solenoid is energized. 2- A hidden button that energizes the solenoid during starting can serve as a security device.
Header shields and ventilation are cures for starter heat soak.
vicrod
Old 03-12-2013, 08:00 PM
Moedog07's Avatar
I sport mine on the firewall of my '55 also.
Old 03-12-2013, 11:45 PM
malc's Avatar
Born To Be Mild
Iīm surprised the custom crowd donīt have a chromed cover for these things.
I did a search and came up with nothing.
Ford solenoid for a Chev starter bentwings Electrical 15 03-22-2012 04:00 AM
ford solenoid I terminal fast68 Electrical 12 01-14-2010 02:23 PM
Switching to Ford Solenoid 1948Butch Electrical 4 09-04-2009 10:24 AM
ford solenoid wiring krustyou812 Introduce Yourself 1 09-21-2004 10:10 PM
'I' wire on Ford solenoid SoCalRoddin' Electrical 1 08-02-2004 01:51 PM
