Covering Armrests - Dantwolakes Alert!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 06:44 AM
protour73's Avatar
These are the armrests that I am using for my door panel project. They are a fibereglass construction with a gelcoat finish. I want to do a layer of Volara 1/4" foam on the top surface. Then cover them in a Whisper faux leather, it has a 27oz. weight.
What steps would I do this in?
Old 04-18-2011, 08:15 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I generally pad these types of things with 1/2" re-bonded foam ( like carpet padding) and then cover that with 1/8" sew foam with the back side up. The Volara foam would also work under the 1/8"sew foam. The sew foam lets the vinyl slip better and it's easier to get the vinyl tight.
You can't do the cover with one piece of vinyl. If it was me doing it, I would cut a piece to match the top, cut out for the pull area and sew a piece into that spot. The area from the top edge down would be a separate piece, and it would have to be curved to take up the slack from the extra vinyl. The seam would then be either top stitched or French seamed.
That's how the armrests in the pictures were done.
ID:	54502   Click image for larger version
ID:	54503   Click image for larger version
Old 04-19-2011, 06:18 PM
protour73's Avatar
Thanks Dan, always appreciat your advice.
I have no sewing machine so it looks like I will end up having to take the armrests into the Interior Shop that did my headliner for me.
So much for a Do-it-myself project!!
Scott
recovering armrests fiddyfofoad Interior 7 02-19-2011 07:31 PM
35 ford/need armrests gary35 Interior 1 12-14-2008 07:28 PM
Building custom armrests? Zooki Interior 10 10-18-2007 03:19 PM
Covering Armrests With Vinyl DanTwoLakes Interior 1 10-12-2007 09:12 PM
armrests Turkey Interior 3 11-25-2004 10:53 PM
