Coverting TH 400 shift linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2002, 12:53 PM
New Member
Cool Coverting TH 400 shift linkage
Running TH400 my one has the fork lever out the left habd side. Then a solid linkage back to the bottom of the shifter. I have got a B&M Quick Silver shifter that i want to put on, this obviously requires a cable. Anyone done this conversion. Any advise apreciated.
Cheers
Sandman
Old 06-09-2002, 03:08 PM
Post
if its a new b@m shifter it should have come with a cable and bracket to fit on the 400,my quarter stick came with everything including bracket to switch to a cable,if not check with jegs,they should sell the cable and bracket
