Cowl Induction Hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2004, 11:46 AM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
Cowl Induction Hood
I want to make my own cowl induction hood for my truck using sheetmetal. Any suggestions, I have another hood for it so that I can experiment with. I was thinking about just buying one that just tapes on or whatever, but I decided that I want a real cowl induction hood so got another hood to work with so that I didn't have to use the hood that is on my truck right now. How should I go about making this?
Old 11-29-2004, 03:02 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
What I would do is take some cardboard and start drawing out some templates. Cut them out and glue them togheter, place them on the existing hood and go from there. Once you'll have a first rough copy you'll see if you want it more curved, higher or smaller etc. If you dont have a metal brake I'd do it in 3 pieces. 2 identical side walls (which will end up looking like bent triangles) and 1 piece that goes across.
Mike
Old 11-30-2004, 06:07 AM
Duck Tape & WD 40
yeah thats what I figured I'd do
Old 11-30-2004, 06:52 AM
poncho62's Avatar
Wiki Edits: 5
I made my own for my Blazer............just bent it with a home made brake, made from a 4 ft piece of angle iron bolted to a metal table. Where it flattens out at the top, I did a small weld...about 3 in each side.
I pop rivetted it on. I should have welded the corners, as the bondo cracked there after I painted it.
That table that it's sitting on is what I used to golt the angle to , to make the brake.
Old 11-30-2004, 07:32 AM
Duck Tape & WD 40
what exactly is a brake and what does it do? I have somewhat of an idea but I figured I'd ask anyway
oh and that looks really cool on the blazer
Old 11-30-2004, 10:55 AM
poncho62's Avatar
Wiki Edits: 5
A brake bends metal..............
Basically all I have is a piece of angle iron bolted to the table so that you can clamp the metal and bend it in a straight line.
Old 11-30-2004, 11:21 AM
Duck Tape & WD 40
cool. Tonight I'm gonna get ambitious and start working on my hood.
Old 11-30-2004, 11:35 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Check this on EBay...if you can understand blueprints and the principle of a sheetmetal brake....http://cgi.ebay.com/ws/eBayISAPI.dll...856137464&rd=1
Old 11-30-2004, 11:50 AM
poncho62's Avatar
Wiki Edits: 5
Just a hint...When you bend the metal for the scoop, don't bend it too sharply. You want a kind of rounded bend.
Old 12-01-2004, 11:35 AM
Duck Tape & WD 40
Figures, my stepdad usually has like 20 sheets of sheetmetal that he uses for his business, he's all out, so now I'm gonna have to wait like a week or two before he gets more.
