Cowl Steering 34 Ford BB
I am working on getting parts for my 34 BB with a speedway disk brake front end conversion.
I understand the things I need to do to achieve a cowl steer setup and I have the original 34 box. I have read that the 34 box is a little sloppy and hard to adjust. Are there any disadvantages to using it? Also anyone know where to find a splined shaft for it so I can extend it through the cowl? Can I just weld some DOM onto the existing splines? then add the correct spline on the other end to attach to the drop pitman? Also, if I don't want to use it, what is recommended? Thanks |
cowl steering.
I ve seen some larger pickup boxes used, they have longer shafts, they turn them so the shaft points out instead of down, also I,ve seen extenders made. a large dia heavy wall tubing, lartge enough to get a nut and socket inside with the splined piece welded on the end. the out side endhass a ring with holes drilled and tapped to bolt on a custon arm. It might be in the Hamb site build picts. I would not weld on the splined end of the sector shaft. heat would ruin the seal and always be leaking grease.
| Ford Cowl Vent query | hitecsedan | Body - Exterior | 1 | 05-18-2009 02:08 PM |
| 38 ford cowl ? | 38harry | Body - Exterior | 0 | 11-11-2008 06:51 PM |
| cowl steering | catman | Suspension - Brakes - Steering | 6 | 10-31-2006 10:16 PM |
| Ford pickup cowl vent | Kruzin Karl | Body - Exterior | 1 | 09-03-2006 04:14 PM |
| cowl located steering box? | gahi | Suspension - Brakes - Steering | 8 | 01-28-2005 08:44 PM |
