Which CR calculator is right? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2010, 12:40 PM
adam83's Avatar
I'm having a hard time calculating my CR. I've looked at 3 or 4 different sites, and I enter the same info for every Calculator, but they all give me different compression ratios!
These are the different CR calculators I used. Which one is right?! Does anyone have a trusted site they use and recommend?
http://www.kb-silvolite.com/calc.php?action=comp
http://www.rbracing-rsr.com/compstaticcalc.html
http://www.csgnetwork.com/compcalc.html
http://www.angelfire.com/fl/procrastination/motor.html
Old 01-06-2010, 01:10 PM
302 Z28's Avatar
All those online programs are is to give you a general idea, none are accurate. The only way to be certain is measure it mechanically.
Vince
Old 01-06-2010, 01:26 PM
adam83's Avatar
I figured that, but the large differences between them was bugging me. Anyways, it turns out I misentered a couple of numbers ... my bad
Old 01-06-2010, 09:13 PM
SSedan64's Avatar
This one you can download to desktop & use any time. >> http://performancetrends.com/download.htm#crc
SBC heads and CR advice needed v8hed Engine 8 06-18-2008 05:04 PM
Cam Duration vs CR Fastest65 Engine 10 03-10-2008 03:13 PM
Deck HT, CR, CC's, cam dur Fastest65 Engine 2 03-07-2008 12:08 PM
hp gains from increased cr classic keith Engine 12 10-25-2005 10:13 PM
piston cr ko.17 Engine 4 03-31-2005 06:13 AM
