CR question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 06:11 PM
CR question
If a SBC is set up at 10:1 CR with 72cc heads, can CR with 64cc heads (no other changes) be easily calculated? Or is life not that simple? Pistons are 0.030 oversize, some dome. Thanks!
Old 03-05-2012, 08:23 PM
DoubleVision's Avatar
It's fairly easy, as long as everything else remains the same such as the head gasket bore diameter and compressed thickness. However to calculate it just right you'll have to know the dome volume as well as how far down the pistons are in the bore at top dead center.
Old 03-05-2012, 11:24 PM
F-BIRD'88's Avatar
Yada Yada Yada
If the cr is actually a real 10:1 now with a 72cc head, it will increase to a 11:1 cr when switching to a 64cc head.
If the cr is not now actually 10:1 the result will be different.
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
Timing question and cylinder head question.. Blackhauk90 Engine 3 05-22-2007 01:10 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
