CR with stroker crankshaft question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2013, 09:21 PM
Zeeb's Avatar
355 SBC, stock crankshaft - If CR is currently 10:1 and nothing is changed, except stroke, to yield 383 ci, what would be the new CR? Is there a rule of thumb for this without getting much into calculations? Current set-up is stock stroke with .030 over TRW domed pistons, 72cc Dart Pro 1 heads. Thanks!
Old 02-27-2013, 09:44 PM
Banned
If you're changing the crank you need to change the pistons or rods as well.
Old 02-27-2013, 10:10 PM
BOBCRMAN@aol.com's Avatar
Go to Keith Black/Silvolite website and check out domes and compression ratios for 383
Old 02-28-2013, 07:09 AM
bondo's Avatar
Ayuh,.... If you change Nothin' but the crankshaft stroke, the pistons will be comin' Out of the cylinders by quite aways....
The pistons will Hit the heads, Hard...
6-71 blown 347 stroker blowing crankshaft seals rojam18801 Engine 3 01-30-2010 11:35 AM
347 stroker with 6-71, blow's crankshaft seal's rojam18801 Engine 11 11-22-2009 03:27 PM
Anyy comments on the Scat 9000 350 main stroker crankshaft with 2 peice rear seal? 74chevyflat Engine 8 09-20-2006 05:31 PM
Crankshaft question StevenC Engine 3 09-03-2005 02:28 PM
Crankshaft question 87442lover Engine 4 08-17-2003 08:54 PM
