Crack around striker - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 12:52 PM
I'm getting ready to redo the doors on my thunderbird and figured maybe I'd try to fix a crack around the driver-side striker. It's not broken all the way around, the door still closes.. but I don't know if this is the sort of thing that you can just seal the crack and move on.. I've been told that this sort of thing requires the metal to be cut out.. weld in a steel plate and start fresh. Anyone ever fix a cracked striker area before it breaks completely, or do you have to cut it out and start over once it starts cracking?
thank for reading..
(just to add, I don't know how the crack started, or how long its been that way.. bought it a few months ago and have just been driving it to and from work)
Old 04-06-2009, 01:25 PM
fast68's Avatar
likes chevy trucks & boobies
surely the doors are sagging due to severely worn hinge pins
and is why the striker is doing this
what year is this car ??
60s?
90s ?
designs of these parts are totaly different
the 94-97 are the worst for this problem
will need to weld to repair it
could grind it in a V and weld into it and grind smooth to repair the crack and stop it
sometimes drilling a hole at the end of the crack will stop it also.
Old 04-06-2009, 01:47 PM
yeah, I already have pins and bushings to do the hinges.. I just wanted to confirm my suspicion that the crack around the striker is beyond my ability to repair at home. (I'm a welderless non-welder)
It's a 95
I was pretty sure this was too high stress of an area to seal with anything. How much should I be willing to pay someone to do (a good job on) this?
(I really appreciate your fast response )
Old 04-06-2009, 01:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
That cracked like that because of a sagging door. if you already have new pins and bushings then the crack will have to be welded and ground down then finished with filler and finally painted. when the striker is removed you need to check behind it to see how far the damage is. cole
Windshield Crack zonk Body - Exterior 6 03-21-2009 03:02 PM
Door striker Pin New Bird Body - Exterior 4 01-22-2009 05:15 PM
One way to fix a crack with pictures. bartamos Body - Exterior 6 03-25-2007 09:48 AM
400 SBC Steam Hole Crack ezobens Engine 5 03-20-2006 08:28 AM
Found a crack in the Number 6 cylinder mercflathead Engine 6 03-27-2005 10:43 PM
