Crack detection in SBC block - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2009, 05:20 PM
v8hed's Avatar
AK427
I'm on the verge of purchasing a cheap SBC Vortec truck engine locally. It's partially stripped (intake and 1 head off) and was removed from the Suburban it was in because one of the heads lost an exhaust seat which ended-up putting a few dings in the piston and the chamber. Also, the same head has a MONUMENTAL crack in it going from one of the bolt holes across the sealing surface of the head. Anyway, the guy has a pair of good L98 iron heads which he's supplying with the engine. My question is this... if the head lost that valve seat due to a severe overheat, it's possible that the block cracked at the same time. Does that sound reasonable? If so, is it essential to magnaflux or pressure-test the block at a machine shop, or are cracks usually visible to the naked eye and a good flash light? I'm taking a bit of a gamble on the engine given what happened to it, but the cylinder bores look good and, being a Vortec, it's a factory roller block.
Old 11-05-2009, 06:13 PM
BOBCRMAN@aol.com's Avatar
I would get the deck surface magged. Also the inner valley above the lifter bores on each side.. Somebody cooked this motor so beware! Most deck cracks are visible IF you know where to look.
Horsepower rating for sbc 4 bolt main block? beemdubya Engine 15 10-29-2009 05:52 AM
355 block... small crack abas_abas Engine 2 03-06-2009 05:51 PM
SBC Question 400 block Jag Daddy Engine 41 06-18-2007 08:31 PM
350 SBC: '70 top end on '90 block? Arcuden Engine 7 09-09-2005 12:49 AM
What about this head sbc block combo. Ed ke6bnl Engine 3 05-12-2003 08:59 AM
