crack in starter mount hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 12:12 AM
hi,today while replacing my starter motor i noticed 2 hair line cracks in starter mounting pad..if that piece breaks off it is looking like it would only be the area where the nurkle piece of the bolt goes..can still torque it up but i'm worried about starter movement if it breaks off..anyway is there anything i can do to stop it breaking and if it does what are my options on fixing it..have spent alot of money on this engine so pretty gutted somthing like a starter may course this much problems...have seen other posts about brackets you can run in between trans and engine but need older style starter...is that the only way to fix the problem if you ever crack mounting hole ?
Old 03-07-2012, 02:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are quite a few threads on this. Use "broken starter pad" in the Google custom search box at the top of the page for more.
Old 03-07-2012, 12:51 PM
NOlowrider's Avatar
US Navy-Retired
I had this happen a few years ago and I went with a in-line starter, rather than the stagered pattern. Worked great for me. I went with a mini hi torque from Summit, no problems. Hopefully you will be lucky too.
Old 03-07-2012, 09:32 PM
its the bolt hole on the outer side so wouldnt help..it was coursed from wrong starter bolts i think..it hasnt broken yet and can still tighten up bolt but its only a matter of time...i run a mini starter due to header cearance..do you know if you can brace them like the old starters to hold it in place tighter.
what do you do to fix a crack where the starter bolt bolts into the block jr19661966 Engine 10 11-05-2011 06:04 PM
P/S Pump mount hole lwin517 Engine 3 07-19-2011 05:34 AM
350 starter mount bolt hole broken... oldschool70k5 Engine 2 03-25-2010 11:55 AM
Vette crack/hole in floorboard Joshwilson Body - Exterior 4 09-27-2009 03:09 PM
400 SBC Steam Hole Crack ezobens Engine 5 03-20-2006 07:28 AM
